rapido 225 with 30mm dell phbh
Posted: Thu Mar 05, 2009 8:56 pm
by king of the hill
any ideas on carbset up for this ?
rapido 225 race with modified scootrs exhaust and 30mm phbh
greetz
tim
Re: rapido 225 with 30mm dell phbh
Posted: Fri Mar 06, 2009 8:39 pm
by J1MS
128 or 130 main, 55 pilot and an x7 needle on the second clip is usually close.....But this is only a suggestion for a starting point...... dont go fitting it and think that it will be ok...do a couple of plug checks to see if its running right and if not ... if your close to a dyno center get it dynoed...All the best
Posted: Sat Mar 14, 2009 6:52 pm
by ferritt
I RAN MINE IN ON THE ABOVE JETTING, NOW RUNNING A 122 MAIN.
Posted: Sat Mar 14, 2009 7:00 pm
by J1MS
ferritt wrote:I RAN MINE IN ON THE ABOVE JETTING, NOW RUNNING A 122 MAIN.
This is the jetting I put in these as a starting point.... usually having to jet down to 122-125
Posted: Sat Mar 14, 2009 7:11 pm
by ferritt
NOT TRYING TO CONTRADICT YOU, JUST THOUGHT I COULD HELP OUT WITH FINAL JETTING ONCE RUN IN MATE.
Posted: Thu Apr 09, 2009 7:27 am
by king of the hill
thanks for all replys !!
got about the same ideas as you lot and it turned out ok for running in .
greetz
tim
