clutch problem
Posted: Sat Jan 29, 2011 3:47 pm
Hi pals, I have a clutch problem on my ts1... now I have an lth clutch but the problem was the same with an Cam Lam one's.
So the problem is the clutch disconnect only in the last 2cm of the lever sroke and the engine don't rise on rpm, rather when I leave the lever completely the engine shuts down...
I think the problem is not on clutch fitting, because I've changed two clutches and two clutches have the same problem, but I really don't understand where is the problem
cheers
alle
cheers
alle
