ss welders
Posted: Wed Jan 26, 2011 12:40 am
by sydduckett
Where would you go to get Stainless Steel welded? I need to find someone to weld a SS bead along the edge of some SS mesh i have cut to fit a air intake. Would need to shape a thin 5m bead along the contour of where its been cut. Would need to spot weld each wire to the back (non-facing) side of the mesh.
Any ideas?
Ta
sef
Re: ss welders
Posted: Wed Jan 26, 2011 1:25 am
by RICSPEED
motor engineer or fabricator
Re: ss welders
Posted: Wed Jan 26, 2011 11:55 am
by Ricko
If the stainless mesh is quite fine, soft soldering or silver soldering may be your only option.
Due to the heat involved in Tig/Tags welding.
Rick
Re: ss welders
Posted: Mon Jan 31, 2011 10:50 pm
by shocky
Ricko wrote:If the stainless mesh is quite fine, soft soldering or silver soldering may be your only option.
Rick
yea as a welder in wouldnt touch it :lol: sometime with things like this the mesh is fusion welded to the thicker section it could be done with laser welding but thats really specialised not the sort of thing a general fabricator would use
Re: ss welders
Posted: Tue Feb 22, 2011 10:45 pm
by Chuck IT
Hi , where are you , my mate does ally & stainless tig welding , near doncaster .
Charlie
Re: ss welders
Posted: Wed Feb 23, 2011 11:11 pm
by sydduckett
Chuck IT wrote:Hi , where are you , my mate does ally & stainless tig welding , near doncaster .
Charlie
Cheers chuck, all sorted now.
