Gear, clutch and throttle cables through the tube
Posted: Tue Jan 25, 2011 9:00 pm
by essexgp
Following advice on here ive run my wiring loom and ht lead through the tube which has given a much neater finish to the cutdown im building. Im now in the process of dry building it and have test fitted the gear, clutch and throttle cables, question is do i fit them in the tube as well as the thing is im concerned about drilling more holes in the tube. Ive got one exiting above the stator, another for the Ht lead above the spark plug and another one for the brake light switch near the pivot.
Any thoughts?
Re: Gear, clutch and throttle cables through the tube
Posted: Tue Jan 25, 2011 9:10 pm
by mark
are you putting a bar for a top tank on as you could always run them down that.on my chop i put wiring, cables and ht thru frame and top tube
my lambretta chopper pride by
mark & anne's photos, on Flickr
hope this helps
Posted: Tue Jan 25, 2011 10:58 pm
by essexgp
No im not, so thats that option out of the way.
Nice chop though :biggrin: :biggrin:
Posted: Tue Jan 25, 2011 11:06 pm
by mark
put them thru the frame its no hassle , as you can see i used tubes then welded them into hole cut into frame .
Posted: Wed Jan 26, 2011 12:34 am
by sydduckett
yeah drill the fu**er...
carefully of course...
I really like the way some people have fluted the holes out of the frame to accept the cables. Way beyond me and how its done im not sure but im sure someone could enlighten us....
Posted: Wed Jan 26, 2011 1:26 am
by RICSPEED
a magic touch and a welder
