Page 1 of 4
Xenon headlight bulb
Posted: Sun Jan 23, 2011 6:05 pm
by Andy Pickering
Seen these mentioned a few times of late and wondering just how good these are..?, was something in scootering a bit back so come on whos using them and are they really as good as they say they are and is it legal to use a blue bulb? I thought blue was only allowed for emergency vehicles...(blue was the one I looked at earlier on Readspeed site)..
http://www.ekmpowershop2.com/ekmps/shop ... 2265-p.asp
Re: Xenon headlight bulb
Posted: Sun Jan 23, 2011 7:22 pm
by coaster
I can't vouch for that type but I have converted both of my scoots to take an H4 lamp and run 55/60 Watt xenons which are a massive imnprovement over the normal 35/35 halogens. I have a standard 55/60 xenen in one and an OSRAM Nightbreaker in the other which is even better. It is necessary to fit an LED rear though to free up enough wattage though.
Posted: Sun Jan 23, 2011 7:29 pm
by Andy Pickering
Is that the set up Mark was doing a bit back? Really was just looking at plug and play option hence anyone had to alter or change anything..
Already running rear led..fettled my gp back light last year to take bgm one...very good indeed.
Posted: Sun Jan 23, 2011 7:31 pm
by Angry Bloke
Lam46 wrote:Seen these mentioned a few times of late and wondering just how good these are..?, was something in scootering a bit back so come on whos using them and are they really as good as they say they are and is it legal to use a blue bulb? I thought blue was only allowed for emergency vehicles...(blue was the one I looked at earlier on Readspeed site)..
I use a yellow one ( only a slight tint TBH) and am very impressed with it although as Coaster says the H4 conversion is better but as a "plug in and play"option the Reedspeed bulbs are pretty good.
Posted: Sun Jan 23, 2011 7:33 pm
by Angry Bloke
Lam46 wrote:Is that the set up Mark was doing a bit back?
No that was an HID set up .
So bright it will give you arc eye
Posted: Sun Jan 23, 2011 7:39 pm
by Andy Pickering
Cheers mr, thats what i was hoping to hear..
Posted: Sun Jan 23, 2011 9:15 pm
by RICSPEED
Lam46 wrote:Cheers mr, thats what i was hoping to hear..
the blue bulbs are ok and only give a slight tint when lit
you need to open up the bulb holder to accsept the bulb primeraly ,then you also need a three pin plug (common to most vehicles)to fit to the bulb but need to break of the collar from the bulb to fit to the j box/holder ,you then need to position the bulb to that the low beam fillament is in the same position as the standard buld to retain the focus on the reflector and glass ,you then need to figure out a method to retain the bulb in the holder ,
ps get a good quality holder as the heat will melt some
Posted: Sun Jan 23, 2011 10:29 pm
by byron
^ if converting to H4, not necessary with the Readspeed bulbs
Angry Bloke wrote: the Reedspeed bulbs are pretty good.
understatement, the lights on your SII are famously phenomenal
Posted: Sun Jan 23, 2011 10:40 pm
by Andy Pickering
Im confused now...lol, Jarv can i just put a readspeed bulb in my scooter restorations bulb holder with no fettle...lol
Posted: Sun Jan 23, 2011 10:43 pm
by mark
Yes
