End can suggestions
Posted: Sun Jan 23, 2011 6:01 pm
The end can on my franspeed rocks in the sleeve, resulting in the exhaust blowing even whgen stuufeed with exhaust sealer....any suggestions?
ta
sef
ta
sef
conical in what way?RICSPEED wrote:idealy the sleve should be slightly conical to ensure a good seal with the retaining springs
Does this fit/slide over the slip joint? If so could well be worth looking into. Anyone used this before?monkey boy wrote:Hi what about one of these???
http://www.lambrettaspares.com/sparepar ... u0445.html
Never tried one but it might be OK.
CHEERS AL
i just meant a lot of high end systems have joints in the pipe that taper slightly so that under tention of the exhaust springs will pull tight ,i not suggesting that yours is like this but this is an example of why it is done ,to stop gaps at the jointssydduckett wrote:conical in what way?RICSPEED wrote:idealy the sleve should be slightly conical to ensure a good seal with the retaining springs
ta
