Ts1 with mukuni tmx 30
Posted: Thu Jan 20, 2011 1:08 pm
by andy3376
Hi is anyone out there running a ts1 with a Mukuni tmx30?
Thanks for all the replies, but no one has mentioned which
atomiser/needle jet they have been using.
Can anyone give me a clue.
Andy
Re: Ts1 with mukuni tmx 30
Posted: Thu Jan 20, 2011 7:36 pm
by Ketje
I run Ts1-230, V-force reeds, JL3 TMX30, LTH-inlet manifold, Stage6 big airfilter.
My settings are : 22,5 pilot ; std needle ; std slide ; 270 mainjet. Never had a problem!!
Mike.
Posted: Thu Jan 20, 2011 8:55 pm
by King Lui 2
Ketje wrote:I run Ts1-230, V-force reeds, JL3 TMX30, LTH-inlet manifold, Stage6 big airfilter.
Mike.
with standard 80 pj?
Posted: Fri Jan 21, 2011 12:40 am
by OzOAP
Engine: T5 casing, AF TS1 barrel, extra boost port, 188/128 port timing, Readspeed centre plug head, Wossner Yamaha YZ 250 piston,
V-Force reed block.
Mikuni fuel pump.
Oil: Castrol TTS @ 3% pre-mix in tank.
Crank: Full circle P200, (57 stroke), widened 10mm. Rotax 120mm rod.
Pipe: PM.
Timing: Parmakit set to 12 deg @ 9000 revs.
Clutch: Old style 7 spring 21 tooth.
Carb type: Mikuni TM30 with CamLam PJ
Main Jet: 200
Needle: 5EL68
Slide: 45
Pilot: 30
Float seat: 3.5
Posted: Tue Jan 25, 2011 1:48 pm
by Ketje
King Lui 2 wrote:Ketje wrote:I run Ts1-230, V-force reeds, JL3 TMX30, LTH-inlet manifold, Stage6 big airfilter.
Mike.
Pj is blocked off....
Mike.
Posted: Tue Jan 25, 2011 7:28 pm
by Dryballs
I use a 220 main, 17.5 pilot, 5el68 needle
Depending on the reeds, I have used a 190 main
it's easy when you know how, download the mikuni tuning manual for an interesting read first
