Page 1 of 2
imola/ extra port
Posted: Mon Jan 17, 2011 11:20 pm
by tea5ive
seen this thread anyone got any ideas. cheeers simon http://www.forums.ilambretta.com/viewto ... 16&t=27586
Re: imola/ extra port
Posted: Mon Jan 17, 2011 11:56 pm
by wack 63
I had this done years ago on a TS1 and wouldn't say it makes much difference.I spoke to Harry Barlow about doing this and he said don't bother.Food for thought.
Posted: Tue Jan 18, 2011 12:25 am
by tea5ive
wack 63 wrote:I had this done years ago on a TS1 and wouldn't say it makes much difference.I spoke to Harry Barlow about doing this and he said don't bother.Food for thought.
cheers for the info wack, there must be a bit to be gained or they would'nt have botherd with the extra bit on the bottom of the cylinder ?. i had this motor (carb) set up on a dyno when i first built it it would be good to see if there is any difference after my home tuning 8-)
Posted: Tue Jan 18, 2011 7:18 am
by rocho68
hi , just check my previous posts under imola , all this work allready done to my cyilinder and casings so i hope it helps :D
Posted: Tue Jan 18, 2011 9:41 am
by soullad
My Imolas had this done for approx 5 years now, plus extra welding to the casings to give a wider gasket face. Only really worth doing if you plan to fit a nice revvy pipe, larger carb etc. Keep gearing to approx 5.4 as you'll find you'll get 20HP quite easily but can be a touch peaky. Standard reeds help to promote torque and the racy V force ones have a rep of only lasting one good season. Would recommend fitting any of the MBD (racetour?) inlet rubbers too, never had a problem with them.
Hope that helps
Ian
Posted: Tue Jan 18, 2011 12:56 pm
by tea5ive
set up will be ....
dellorto vhsh 30mm
v force reeds
mbd rev-tour exhaust
varitronic ignition
head is set at 10.5 = 1
clutch is a ssc cassette type, 5 plate
gearing is li150 on to 15/46 ( would not pull a 16 in winds or up hill)
last dyno when first built was 19bhp
exhaust was a scootrs pm copy
carb was phbh 28mm
no tuning on cylinder, straight out of the box
ignition was imola "eta" ( a bit like an agusto box) on indian set up
Posted: Tue Jan 18, 2011 4:16 pm
by rocho68
is this what your planning .............................ImageImage
Image[/photobuckvid][/photobuckvid]
boost port the same as rbs............
Posted: Tue Jan 18, 2011 10:51 pm
by tea5ive
thats a bit beyond my tuning skills, but yes thats what i am after. very nice bit of work 8-) 8-) . anyway i could not resist more tinkering today, i drilled the boost port into the inlet today :D .
Posted: Wed Jan 19, 2011 1:19 pm
by Toddy
You have to much time in that garage Simon :lol: :lol: :lol:
Posted: Wed Jan 19, 2011 8:53 pm
by tea5ive
Toddy wrote:You have to much time in that garage Simon :lol: :lol: :lol:
perks of the new job, but not good as to how ive got the job. r.i.p dad :cry:
