25mm dellorto
Posted: Mon Jan 17, 2011 10:29 pm
by Arch_Stanton
200 Rapido Classic with 42mm clubman, 25mm phbl through the airbox with std SX200 gearing.
Can anyone recomend an initial jetting setup for the carb?
Re: 25mm dellorto
Posted: Tue Jan 18, 2011 9:56 pm
by 22/2
Arch
I have a very similar set up in a series 2 through a wide neck TV air box, I'll dig out the details and let you know.
I'm in work right know so may not get to it until tomorrow evening.
Rich
Re: 25mm dellorto
Posted: Tue Jan 18, 2011 10:16 pm
by Arch_Stanton
Cheers Rich.
Re: 25mm dellorto
Posted: Wed Jan 19, 2011 10:25 pm
by 22/2
Arch
I'm using
Main jet 91
Pilot jet 50
Atomiser AQ268
Needle D29 on T3 clip position.
Slide - I haven't written it down sorry, but it's probably a 40.
When I fitted the carb I struggled to get it to work, borrowed a carb of a mate with a similar set up (not Rapido) it worked so set mine up the same, it's still very rich throughout but that may or may not apply to yours.
Rich
Re: 25mm dellorto
Posted: Wed Jan 19, 2011 10:31 pm
by Arch_Stanton
Cheers for that Rich.
