semi hydrolic clutch
anyone got one or some pics dont want to mod the side case and looking for something i can do myself lookin at the hebo kits any views
noggin1969
I,ve got one on mine , although i think you could make it cheaper with the slave cylinder from E.Bay pit bike and a second hand master cylinder say from a Gilera runner. The Hebo kit hydraulic hose is too short anyway so you'd have to buy alonger one. The slave cylinder can be fitted to the cable adjuster block where the clutch adjuster screws in.
Has a mind full of useless s**t and isn't afraid to use it !
ive been looking at the ebay kits and i have a AJP master cylinder on the brake so the other side will be the same
noggin1969
the hebo slave is abit too fat to fit on the adjuster block without modifying it , but it's simply enough to do. i put one on after severing the tendons in my left hand and it is light to use. the pit bike slave cylinder is thinner and can be screwed into the adjuster block. Pearsons will do you a hose of any lenght you want with screw on bangos
have you got a pic of the adjuster end PM me if you dont want everyone to know and have you cut the gear housing at all, or does the master cylinder just but up to the housing were the end of the grip would go
noggin1969
The clutch lever housing was cut back so the AJP master cylinder would fit flush , the clamp part is a couple of mm too small so abit of filing will be needed. I fitted my slave cylinder to the swinging arm of my rear disc. The pit bike slaves being small will screw into the adjuster block. The pic is of the Simpson racer were it looks as though he's made a bracket to fit the slave further back to make room for it.
    Users browsing this forum: Baidu [Spider] and 9 guests
