Lighting coil resistance
Posted: Sat Jan 15, 2011 1:10 pm
Hi,
I'm building a DC system using a Wassell regulator/rectifier, so I have wired the four lighting coils together and run a yellow wire from each end of the series. When I run the scooter, I get a rather poor 4.5v AC out of the two yellows and no increase in output with a rise in revs.
Now what I have done is not so different to most AC systems, it is just that output on AC systems is measured between the one yellow and earth. However, output on such a system usually rises to 16-18v without many revs.
I have checked the resistance on three stators (a Vespa stator, an Indian stator and my new stator) and the readings are not consistent.
What should the resistance of the 4 lighting coils be? Can someone take 5 minutes to measure between their yellow wire from the stator, and earth? You don't even need to start the engine. The more replies I get, the better.
Thanks in advance
Thanks in advance
