Page 1 of 2
Rubber O Rings for Bullets TS1 exhaust?
Posted: Thu Jan 13, 2011 4:15 pm
by wax
I had a new exhaust from SIP, that looks great but it did not come with a couple of rubber o rings for the manifold. After half a dozen emails to SIP (they keep telling me i need a beedin' gasket kit!) I took it to an MX mate of mine who said his KTM had a similar set-up and so i ordered a pair of rubber rings to fit a 250 KTM, but they are too dam big. £12 quid lighter and a scooter still in bits.......
Do i need Viton seal for an exhaust or summat else? I wanted to get a dyno run and get on the road, but this hole thing is turning into a right pain in the arse!
http://s634.photobucket.com/albums/uu68 ... ullet2.jpg
http://s634.photobucket.com/albums/uu68 ... ullet1.jpg
P.S. i hope these links work. I am rubbish with computers (as well as scooters)
Re: Rubber O Rings for Bullets TS1 exhaust?
Posted: Thu Jan 13, 2011 4:26 pm
by leigh
That loks very similar to the style that is on my franspeed sure he does replacements on his website
Leigh
Posted: Thu Jan 13, 2011 5:48 pm
by wax
is this what you mean? It does not say if they are rubber or not. Its a rubbish picture too......?
http://www.ekmpowershop12.com/ekmps/sho ... -336-p.asp
Posted: Thu Jan 13, 2011 9:35 pm
by Adspeed
Just completed an exhaust shoot out today-15 pipes I think!! One was the Bullet, no O'rings also............We used HT Sealant as needs must........
Posted: Fri Jan 14, 2011 6:29 am
by stefan 231
Hi.
The material of the missing rings are viton.
diameters 40 x 1,5 mm.
best regards, stefan
Posted: Fri Jan 14, 2011 8:40 am
by leigh
Couldnt say from that picture to be honest, sure if you ring he could answer or do as others have said used a sealent.
Leigh
Posted: Fri Jan 14, 2011 9:01 am
by ArKaTxU
I use sealant on my JL Franspeed and goes well.
Posted: Fri Jan 14, 2011 10:34 am
by wax
What like a special high temp paste? Any brand in particular chaps?
Posted: Fri Jan 14, 2011 3:25 pm
by leigh
Adspeed wrote:Just completed an exhaust shoot out today-15 pipes I think!! One was the Bullet, no O'rings also............We used HT Sealant as needs must........
are you going to put the results up here
Leigh
Posted: Sat Jan 15, 2011 8:56 am
by wax
Do you mean dyno results? If so then yes no problemo. I am aining for 30th Jan at Diablo, but i havent booked yet. I need to get my EGT weld on boss fitted too. I have emailed MD developments, but they have not replied?
I have also ordered some viton o rings from AF rayspeed. So hopefully they will fit. My ts1 240 made 36 bhp on JB tunings dyno with a franspeed. It had a little more porting on the cases, when i had it stripped last by JB, so with the Bullet i am hoping for a few HP more.
