Page 1 of 4
Anti dive question again
Posted: Sat Jan 08, 2011 3:19 am
by red ghost
Re: Anti dive question again
Posted: Sat Jan 08, 2011 4:14 am
by RICSPEED
rose joints for me
Posted: Sat Jan 08, 2011 8:21 am
by mark
spacer will be fine m8 and use rose joints for bar
Another anti dive question
Posted: Sat Jan 08, 2011 8:54 am
by red ghost
Regarding the postion of the caliper on the disc, the static brake pad side should be just off the rotor, or should the gap between both pads be even off the rotor?
I'm leaning toward the former...
Posted: Sat Jan 08, 2011 11:05 am
by jason frost
Set it up even, but the caliper floats so it will move.
Posted: Sat Jan 08, 2011 9:51 pm
by Knowledge
Nice work Frank, and surprisingly close to my version of the caliper bracket (though yours is rather neater).
As you know from previous pm's Frank, I opted for a four pit opposed caliper. This just seems like an easy route to centralising the caliper. It does need more clearance behind the disc, as the four pot caliper is simply wider.
My tie rod is based around rose-joints acquired from the steering tie-rods of a kart. They are cheap, but you need an M8 lefthand thread tap for one end.
Whilst you have taken the decision to junk the speedo drive, have you done so in order to keep the caliper on the RHS? After trying to accommodate the speedo drive and the caliper on the RHS, I suddenly realised that there was no need to keep the caliper on the RHS when you are using an anti-dive set-up. If the caliper bracket is intended to pivot about the axle, then the second fixing on the RHS suspension link has no role in the brakes. It can still be used as part of the cut-down speedo drive.
I could not accommodate all the compoenents for the front brake until the caliper found its way to the LHS, though I guess this is of little comfort if you have already welded the top fixing for the tie rod onto the RHS fork leg.
Here is a photo of the brake during construction (rotated for your benefit)
Posted: Sat Jan 08, 2011 10:31 pm
by red ghost
Hi Martin,
I like your work. And to keep things simple for me it's all on the RHS, I'm using a 'far east pressure cast hub'.
oh, and choke cable works a treat!, now I just need a new choke assembly.
Posted: Sun Jan 09, 2011 2:46 am
by RICSPEED
yamaha caliper martin?
Posted: Sun Jan 09, 2011 11:25 pm
by Knowledge
R1 mono-bloc thingies. I think they also fitted them to FZR models. The finished item:
Posted: Mon Jan 10, 2011 8:33 am
by red ghost
Martin, your hose looks a little tight..
