problem with cold starting .......
rocho68
mates lammy is a nightmare to start from cold but if you put your hand over carb (25mm delly) it fires first time ! any ideas boys.................?
JDale
Main scooter: Lambretta Jet 200
If Choke is working make sure the choke plunger is moving up corretly, if it is you need a bigger choke jet. I had the same problem and exact same hand over carb sorted it. Changed to a larger choke jet and my problem was solved
    Users browsing this forum: No registered users and 21 guests
