Rear lights
Posted: Tue Jan 04, 2011 3:25 pm
by sydduckett
Iv cut vents into the rear of my panels and want to put some additional rear lights in them behind the wire grills im puting in. Ideally looking for lights that work on both rear light and brake. They will need to be quite small and have a connector on the back so i can disconnect them when taking the panels off. Im thinking LED or similar? I am running 12v without a battery.
sef
Re: Rear lights
Posted: Tue Jan 04, 2011 5:07 pm
by rbgaz
av look in halfords sef they do allsorts 12v led stuff
Re: Rear lights
Posted: Tue Jan 04, 2011 5:09 pm
by sydduckett
rbgaz wrote:av look in halfords sef they do allsorts 12v led stuff
need some easy to disconnect connectors as well
Re: Rear lights
Posted: Tue Jan 04, 2011 6:47 pm
by essexgp
I think this would work for what you are wanting to do
http://www.maplin.co.uk/Module.aspx?Mod ... connectors
:idea: :)
Re: Rear lights
Posted: Fri Jan 07, 2011 9:33 pm
by ratty
hi, you could modify the led stop and brake light unit thats already available for lammys, if your handy with a soldering iron and a bit of fettling,buy the whole unit and you will have everything you need.
Re: Rear lights
Posted: Fri Jan 07, 2011 10:42 pm
by Knowledge
Sef,
You can pop over to mine (A12, south of Ipswich) and see some conenctors I have in stock, along with cables, terminals, tools and my own versions of LED lights that I have fitted to the Abarth.
Re: Rear lights
Posted: Sun Jan 09, 2011 7:30 pm
by sydduckett
Knowledge wrote:Sef,
Mart, how about i pop over to yours with a some cash pick what i want and then have a cup of tea while you fit it for me... ;) Im not to clever with the old electrics and someone like you could do this whilst asleep. I will be happy to pay for the labour. Shall we say £15ph. im guessing 45 mins and a couple of gary baldies and all will be done...
You know it makes sense.... :D
Re: Rear lights
Posted: Sun Jan 09, 2011 11:18 pm
by Knowledge
OK, I'm (probably) up for that, but I don't have any lights to fit, only examples of what you could buy to suit your own requirements.
You don't want a battery, but LED's will not work at their best on AC power alone.
