AIR FILTER re 24TM & 238cc
Posted: Sun Jan 02, 2011 7:11 pm
I have been trying out many air filter set ups and this is my final air filter set up after loads of testing this works best and will be used on the XL with its 238cc reed rapido top end. Spanish air filter toolbox as a base.
This show the original air feed is blocked off and a new one 40mm dia is added
The original Spanish filter plate is replaced with a new plate and pipe to suit the GP air hose, no filter is on the inside of the box , its simply for connection.
This shows that an extra large tank can also be fitted.
So you have a large plenium chamber after the filter which is in the toolbox. Small tools can still be carried in the tool box. But I use a legshield toolbox.
The air flow is such that I can now run a 210 main on my Mikuni TM 24 which is as per when run as an open carb.
