speedo cable?????
Posted: Tue Dec 14, 2010 4:32 pm
by C*NTSPEED
got a scoot rs outboard set up speedo drive looks perfect however when i connect speedo cable to mini speedo i carnt get it to work?
is there different hieghts of the timny clamps on inners?
by that i mean it looks like the tip of my inner is just not quite long enough
Re: speedo cable?????
Posted: Tue Dec 14, 2010 7:01 pm
by wack 63
I use a long nail that I filed into a square on the end and push it into the speedo drive then spin the wheel.If it turns ok then I know the problem is with the cable which may need the outer shortening and some of the sleeving trimming back.If the nail doesn't turn then the drive could be tight,unscrewing the outer holder on the hub sometimes lets the drive worm turn.Also seen the worm square too big to grip the inner.
Posted: Tue Dec 14, 2010 7:38 pm
by C*NTSPEED
wack 63 wrote:I use a long nail that I filed into a square on the end and push it into the speedo drive then spin the wheel.If it turns ok then I know the problem is with the cable which may need the outer shortening and some of the sleeving trimming back.If the nail doesn't turn then the drive could be tight,unscrewing the outer holder on the hub sometimes lets the drive worm turn.Also seen the worm square too big to grip the inner.
ta very muchy ;)
