Horn
Posted: Tue Dec 14, 2010 1:10 pm
by dapper
Having just completed my Injun Vijai Super resto, have the ubiquitous duck fart AC horn. What can be done to make it at least audible :roll: Is there another type of horn that will sit on the same bracket under the horncast that could be heard by pedestrians/car drivers?
Re: Horn
Posted: Tue Dec 14, 2010 7:07 pm
by wack 63
Have you 12 volt electrics? If so I have found 6 v horns give more volume although it's still a duck fart but thru nipped cheeks.....
Re: Horn
Posted: Tue Dec 14, 2010 11:26 pm
by Honeymonster
Hi Mark, tried a few different horns but all gave typical duck fart noise when needed, have come to the conclusion that a full DC conversion, with a battery wired in, is the only way, you usually only need a horn when your throttles closed and braking. I got a horn from a company called Acumen which is very good but have tried a very cheap DC unit and it was fairly good.
Otherwise it's a gas canister and air horns, very 70's
good luck Ian
Re: Horn
Posted: Wed Dec 15, 2010 1:08 am
by Muttley McLadd
If you fit a battery, I can recommend a Stebel air horn. Wouldn't fit under the horncasting, but they're reasonably tiny. You could hide it underneath quite easily.
Re: Horn
Posted: Wed Dec 15, 2010 12:47 pm
by dapper
Yeah, my other Bitsa has a DC horn fed via a battery in the toolbox and its feckin loud. May have to go for that
Re: Horn
Posted: Wed Dec 15, 2010 1:41 pm
by RICSPEED
i think the duck fart horns are quite funny :D
