Ring Life - standard engine
Posted: Sun Dec 12, 2010 4:54 pm
by sideout
What sort of mileage would you expect to get out of a set of piston rings in a standard SX150?
Thanks in anticipation :wtf:
Re: Ring Life - standard engine
Posted: Sun Dec 12, 2010 5:34 pm
by bristolmod
standard as in an air filter fitted and running, say semi synth at 3%.
I recon anything between 5 and 10,000 miles at a push
Chris
Posted: Sun Dec 12, 2010 6:43 pm
by sideout
Cheers Chris
Air filter, 22mm Jetex, Clubman and 4% Rock Oil Semi-Synthetic.
Posted: Sun Dec 12, 2010 7:50 pm
by bristolmod
yep- I'll still go with 5k minimum. If it then needed new rings, I'd probably go for a rebore and new piston rather than faff around with just rings
Chris
Posted: Sun Dec 12, 2010 10:59 pm
by joey
...keep going until you loose compression...decoke at around 5000m and check ring gaps.....modern oils should keep the carbon clear for longer though...nice loose barrels let the engine rev freely....
if in doubt bin it and fit a mugello.... :lol:
Posted: Sun Dec 12, 2010 11:43 pm
by soosh
You should be fine for at least 10k. Ive probably done that on a standard piston with open mouth carb on a revier motor so no worries.
Posted: Tue Dec 14, 2010 4:37 pm
by Special X
20k plus no worries. Even a tuned mugello (rock hard nicasil bore) will do 10/12k set up correctly with 3% synth and an air filter.
