RAMP rear hubs
Posted: Sun Mar 01, 2009 10:04 pm
by Bufficus
Rear hubs made by RAMP.
I seem to remember reading that these are sh1t and should be avoided.
Just discovered one on a mate's scooter. Time to replace it?
Re: RAMP rear hubs
Posted: Sun Mar 01, 2009 10:31 pm
by ArmandTanzarian
Mine was sh1t because it wasn't round and didn't sit on the splines correctly. If your mate's fits ok and the brakes work then I'd leave it.
Re: RAMP rear hubs
Posted: Mon Mar 02, 2009 11:31 pm
by Arfur
get rid mine cracked in the main part and two lugs snapped. Luckily I noticed it on a routine inspection or it could have been serious
Re: RAMP rear hubs
Posted: Mon Mar 02, 2009 11:44 pm
by Bufficus
Thanks for the replies fellas.
Lots of bad reports on the other site as well.
I'm going to destroy the RAMP hub so it can't be used and fit a new one.
Re: RAMP rear hubs
Posted: Tue Mar 03, 2009 1:08 am
by shocky
you could use it as a hub skimming tool just super glue some coarse emery paper about 15 cm long and rotate by hand slowly tightening the adjuster it scims the high spots or in my case 1 mm of the whole of the bottom shoe due to it being an indian case
Re: RAMP rear hubs
Posted: Tue Mar 03, 2009 10:51 am
by Soulpunk
problem is that they come without cone.
its not possible to find a correct cone as noone will fit properly.
they have to be machined specially.
apart from that the quality seems to be unsatisfying on a great percentage.
just talked to a scootershop-owner and he said the binned all 20 of them.
i just bought one from ebay, i will bin it and keep the studs.
Re: RAMP rear hubs
Posted: Tue Mar 03, 2009 11:57 am
by 100mphlambrettaclub
Leave well alone i wouldnt put one on a wheel barrow
