in gear, clutch in, won't roll back??
Posted: Thu Dec 09, 2010 3:06 pm
by Suede Ed
Rebuilt Indian gp 150, running ok, nearly coming up to MOT (when i sort the back brake), just noticed i started her up in the garage and when the scoots in gear with the clutch in, the thing will not roll backwards? any ideas, clutch?
Re: in gear, clutch in, won't roll back??
Posted: Thu Dec 09, 2010 3:47 pm
by lammy mark
Are the side panels on or off? if they are off, check that the panel clips are not catching in the back tyre.
Posted: Thu Dec 09, 2010 4:47 pm
by Suede Ed
Done that before Mark! Its not the clips
Posted: Thu Dec 09, 2010 4:59 pm
by RICSPEED
will it not move at all ,or get progressively harder then stops?
Posted: Thu Dec 09, 2010 6:04 pm
by bsso78
Its probably the kick start plunger catching on first gear
Posted: Thu Dec 09, 2010 6:18 pm
by gerryjunior
yes happened to me before ,it was the kickstart catching first gear as stated..
Posted: Thu Dec 09, 2010 6:49 pm
by RICSPEED
so does it click when pushing forward ?
Posted: Thu Dec 09, 2010 10:31 pm
by Suede Ed
yeah, i think it clicks, does it matter? And the remedy? case cover off and... Thanks again gents
Posted: Thu Dec 09, 2010 10:44 pm
by RICSPEED
check the reference pin on the kickstart piston for wear and may need to adjust ramp on side case
Posted: Thu Dec 09, 2010 11:04 pm
by bsso78
Take the kickstart pedal off first,if the shaft turns back when you do then youve had the lever one spline too high.
Assuming that it turns back just put the lever back on and it will be fine.
If it doesnt turn back then you need to take the sidecasing off and have a look at the plunger,if its a GP sidecase then it wont have a ramp to adjust so its probably worn around the plunger pin and sitting too far out.
