good spec or not
Posted: Sun Dec 05, 2010 5:38 pm
by ducksta
vespa 200 electric start malossi 210 casings matched crank cut, flywheel lightend, standard carb modified, advance retard, cosa clutch banded, t5 4th gear. jl right hand exhaust will this be a good tourer? keep auto lube or not?
Re: good spec or not
Posted: Sun Dec 05, 2010 6:58 pm
by goldeneye
yip. pretty much what i ran for a while, except the advance retard. kept the autolube , and ran it on CASTROL TTS fully synth (i used to get it cheap) and stuck an extra glug in the tank for motorway use. jets were 190 air corrector, BE3 middle tube, 130 main, 50/100 pilot, two turns out on the mixture screw. ran it to work and back, rallies , shopping, etc. never skipped a beat. the flywheel was a standard electric start lightened with the ring gear removed, but if i did it again, i would keep the leccy start, the flywheel was light enough. pulled like a train, and was good on fuel.
Posted: Mon Dec 06, 2010 7:27 pm
by ducksta
cheers m8 thats what i wanted to hear
