Page 1 of 3
stage 4 or classic rapido
Posted: Sun Nov 28, 2010 9:59 pm
by Tosh
Brothers scoot has just locked up,its a stage 4 now he`s wondering if he should get a new stage 4 top end or a classic rapido 200 or i suppose he could get it rebored to 225, anybody had one of the classics and what do you think
Re: stage 4 or classic rapido
Posted: Sun Nov 28, 2010 10:17 pm
by Muttley McLadd
How badly damaged is it?
Posted: Mon Nov 29, 2010 1:17 am
by corrado
Just get a decent 66.4 piston, rebore and hone.
Posted: Mon Nov 29, 2010 9:35 am
by Tosh
thanks for replys, would i need to get the head done as well
Posted: Mon Nov 29, 2010 10:46 am
by poose
I got sick of my stage 4 keep seizing or holing pistons so got a Classic Rapido put on and found it to be much better performance and more reliable, you can get a 225 version of the classic as well. Running my 200 with a 30mm dellorto and reverse cone clubman its got plenty of grunt and good acceleration.
Posted: Mon Nov 29, 2010 11:14 am
by fairspares
a seizing barrel and holed pistons are usually down to either air/fuel mixture , timing or incorrect clearance of piston/barrel , there is nothing wrong with the stage 4 indian barrels , the rapido has an outer alu jacket so will have much better cooling than a all iron barrel , but both will seize if not set up properly. you will need head machining if going to a 225.
Posted: Mon Nov 29, 2010 1:33 pm
by poose
My jetting was spot on when it seized its just that I like riding full throttle all the time and they wont take it but the Rapido does, better cooling.
Posted: Mon Nov 29, 2010 2:00 pm
by Tosh
not checked to see how bad its is at mo will see him at weekend,if i knew how to put a photo on the web page i`d show you all
Posted: Mon Nov 29, 2010 6:40 pm
by Jazzy
Tosh wrote:not checked to see how bad its is at mo will see him at weekend,if i knew how to put a photo on the web page i`d show you all
are you sure its the top end.
is the engine a indian one with sil crank?
if it is my moneys on the crank
Posted: Mon Nov 29, 2010 7:23 pm
by soosh
I run a stage 4 (genuine) and been 100% reliable. Things sieze for a reason,not because its iron. I can run it flatout with confidence.Better off sorting it out rather than just buying a new topend.A proper stage 4 should shite all over a Rapido classic and still pull very well and rev.One thing to check on Indian barrels is the bore clearence,apparantly they can be all over the place.Two of the best motors ive ever had have been iron and cheap to put right if all does go wrong.
