Does "ebay" 66mm pistons with 2x1,5 rings do the job?
Posted: Thu Nov 25, 2010 6:56 pm
by Stian
I need a 66mm pisotn with thin rings. Its going in a low rew st type engine. I want to pay as little as possible. Will the 30£+- priced pistons sold on ebay do the job? Any experiance?
Re: Does "ebay" 66mm pistons with 2x1,5 rings do the job?
Posted: Sun Nov 28, 2010 10:16 am
by coaster
Stian wrote:I need a 66mm pisotn with thin rings. Its going in a low rew st type engine. I want to pay as little as possible. Will the 30£+- priced pistons sold on ebay do the job? Any experiance?
I have no experience of them but if as you say, it's going in a low tune engine then I would imagine it'll get the job done. Make sure there's at least 3.5 thou clearance and get the barrel honed if not.
Posted: Sun Nov 28, 2010 10:38 am
by bristolmod
I'd be inclined to go for a "Mahle" from Scooter Restorations:-
http://www.scooterrestorations.com/lamb ... -assembly/
Used them many times with no problems at all (even running 3 thou clearance)
Posted: Sun Nov 28, 2010 11:00 am
by eibargum
If money allows you can buy a 66mm Asso for about £60, a better bet IMO.
Posted: Sun Nov 28, 2010 8:35 pm
by goldeneye
if they are the same as the cheapo indian pistons with crap brittle rings, made of cheese, that are doing the rounds of late, steer clear. buy a Mahle from scooter restorations for 40 quid . saving ten quid is daft really. the rings will last five minutes on the cheap job. mahle are ok really, for standardish motors. i used to make the piston rings for Mahle, and their tolerances were up there with the best of them.
Posted: Mon Nov 29, 2010 4:42 pm
by dirtyhandslopez
goldeneye wrote:if they are the same as the cheapo indian pistons with crap brittle rings, made of cheese, that are doing the rounds of late, steer clear. buy a Mahle from scooter restorations for 40 quid . saving ten quid is daft really. the rings will last five minutes on the cheap job. mahle are ok really, for standardish motors. i used to make the piston rings for Mahle, and their tolerances were up there with the best of them.
How are suppliers/shops over there as far as supplying the correct rings? I seem to have very liitle luck this side of the pond getting the correct rings, shops only want to sell complete pistons.
Posted: Tue Nov 30, 2010 12:54 am
by goldeneye
generally ok mr.lopez. everything , even oversizes for most popular set ups , the english dealers stock, or if they dont, will split a piston kit to give you the rings if you know the right people. scooter parts dealers get slagged off, but most well known ones are scooterists as well, and just want to see people on the road. i suppose its more difficult stocking stuff your side of the pond. people have a moan over here, but really, its dead easy to get anything you want, usually in 24-48 hours. AF RAYSPEED.. 40 miles away, andy francis... 80 miles away... beedspeed 70 miles away.. motech ... 35 miles away. couple of local auto shops for cables and oil etc (1 mile away!) and a car auto shop i have trade account with for 2 stroke , bulbs , bodywork stuff etc. 200 yards away! :D
Posted: Tue Nov 30, 2010 2:44 pm
by dirtyhandslopez
I'll be in touch then...
