Drive Side Bearing Flange Screw
Posted: Fri Feb 27, 2009 6:26 pm
by Snails
Can anyone tell me if these are the same size for large and small frame lambrettas?
Re: Drive Side Bearing Flange Screw
Posted: Fri Feb 27, 2009 6:32 pm
by Dell Oughta
Posted: Fri Feb 27, 2009 8:02 pm
by shocky
JUST BE VERY CAREFULL IF YOU USE THE ALLEN HEADED ONES AS THERE EASY TO ROUND I HAD TO DRILL 2 THAT SOMEONE HAD MISS FITTED ROUNDING THE HEX SLOT
IVE NEVER HAD A PROB WITH THE SLOT TYPE ,ALSO DONT GO DAFT WITH THE RETAINING COMPOUND IF YOU USE IT MEDIUM STRENGH ONLY NOT 638
Posted: Sat Feb 28, 2009 10:37 am
by Snails
cheers shocky you put me off the allen head ones now.
Posted: Sat Feb 28, 2009 12:56 pm
by shocky
there prob ok if you have good allen keysits just i know i can get a slot headed one out even if the slot is shot a small impact drivers works for me i tried it on the allen headed screws but to no avail
the knackerd allen headed ones all i did was sharpen a drill to the same profile as the countersink and take the heads of lift the plate and the thread that was left came out with small pliers , luckily they had not bottomed out
Posted: Sun Mar 01, 2009 7:23 pm
by TS1-200
I must admit I had trouble getting an allen headed one out, what I did was to dremel a slot in to undo it with a screw driver, I always use the standard slot type now.
Posted: Sun Mar 01, 2009 7:28 pm
by Angry Bloke
Also make sure you use a steel plate not an alloy one
Posted: Sun Mar 01, 2009 7:37 pm
by shocky
i have a steel drive side plate if you want on £5 posted
