Mag housing damage / Up gearing
Posted: Sun Nov 14, 2010 1:46 pm
by djh66
1. In my clumsyness to get the mag bearings out, i've damaged the inside lip of the housing
Is it still OK to use?
Uploaded with
ImageShack.us
2. What will, changing my front sprocket (150 special, ali 185 kit) from a 15 to a 16 give me, in terms pof performance?
Dave
Re: Mag housing damage / Up gearing
Posted: Sun Nov 14, 2010 2:35 pm
by joespeed
yes it will be ok to use,leave the gearing as it is and try it!
regards
joe
Posted: Sun Nov 14, 2010 4:55 pm
by djh66
Thanks Joe, that's a relief. I'll leave it as is, for time being, but what would it do if I changed it to a 16 tooth?
Posted: Sun Nov 14, 2010 5:53 pm
by Skar
djh66 wrote:but what would it do if I changed it to a 16 tooth?
In theory, give you a higher top speed, in reality it likely won't pull it or will struggle to pull it, unless you have done other mods? Better to stick with the 15 or at least give the 15 a try...
Posted: Sun Nov 14, 2010 10:28 pm
by WINTERMODEL150
Hi the mag housing will be fine to use as its the shoulder that the seal sits up against,just check that its not cracked at all around that area,i've used a few like this before with no problems.
Regards Dean.
