Gearbox Rebuild
Posted: Sat Nov 13, 2010 8:47 pm
by djh66
I'm rebuilding my recently aquired Italian imported 1965 150 special. I striped the engine and gearbox to inspect and/ or replace any components deemed necesary.. The gearbox seemed ok so I'm rebuilding it with the existing components following stickys manual, but my first gear seems to sit too deep, and the large shim floats about! I tightened the layshaft up tight using the hub / nut method. I did not notice if it was like this when I took it apart, anyone shed any light??
Re: Gearbox Rebuild
Posted: Sat Nov 13, 2010 9:28 pm
by fairspares
if you have put the 4th gear in the right way? , and torqued down the rear hub/nut correctly then all you will need to do is fit correct shims to achive the correct clearance . changing some of the gearbox parts can alter the clearance so its a good idea to keep a set of various shims.
Re: Gearbox Rebuild
Posted: Sat Nov 13, 2010 9:41 pm
by djh66
fairspares wrote:if you have put the 4th gear in the right way? , and torqued down the rear hub/nut correctly then all you will need to do is fit correct shims to achive the correct clearance . changing some of the gearbox parts can alter the clearance so its a good idea to keep a set of various shims.
fantastic! Your first 11 words made me think!
I believe, after reading the book again, I've got the fourth gear the wrong way round!!!!!!
Will check tomorrow, and report back
Re: Gearbox Rebuild
Posted: Sat Nov 13, 2010 10:44 pm
by djh66
Could'nt wait till tomorrow
Just been out in the garage, and, fairspares, you were spot on, cheers. Now gearbox looking and shimming good
Re: Gearbox Rebuild
Posted: Sat Nov 13, 2010 10:50 pm
by fairspares
glad to hear you sorted , it can be a bit confusing which way the 4th gear goes.
Re: Gearbox Rebuild
Posted: Sun Nov 14, 2010 4:08 pm
by paulmgreen
nice one... all sorted...
