End can bracket leak?
Posted: Fri Nov 12, 2010 6:30 pm
Have one of the new style end can brackets for a Franspeed race and have oil leaking from what looks like the lowest stud of the 3 and possibly coming from the gasket seal in the same area.
Iv already snapped one stud trying to tighten them up...
and had to take the whole chain case off, so have tightned them and the allen key bolts up as much as i dare. Im using brass washers that compress to try and get a good seal. When i had my prev NK pipe on that doesnt have an end can bracket the normal studs were fine, so i have to presume that the bracket is the problem? Might be that the allen key bolts arent tightening down eneough meaning that the casing doesnt seal tight in that area maybe?
Would gasket sealer work or is that only going to mask over the problem?
Any one have any ideas
Ta
sef
Ta
sef
