Page 1 of 2
Can you buy these anywhere?
Posted: Tue Nov 09, 2010 8:03 pm
by soosh
The retaining clip for the bottom buffer in my forks is busted,can you buy anywhere the retaining clip to weld in? Tried Scooter restorations but no good.There must be some anorak with a collection of them in an old Golden Virginia tin.
Re: Can you buy these anywhere?
Posted: Tue Nov 09, 2010 8:06 pm
by soulsurfer
They're not difficult to make from sheet steel, I feel this might be your best option
Posted: Tue Nov 09, 2010 8:14 pm
by RICSPEED
what he said ...strip of steel ....measure a rubber and bend in a vice or something....getting the old out and clean is an arse somtimes though
Posted: Tue Nov 09, 2010 9:34 pm
by byron
or convert to bolt-in bottom buffers..?
makes rebuilding the forks a whole heap easier
Posted: Tue Nov 09, 2010 9:44 pm
by essexgp
Did that to mine when one of the bottom clips broke, made them bolt in at the bottom only, much easier to fit the bottom buffers now
:biggrin:
Posted: Tue Nov 09, 2010 10:00 pm
by MarkH
I'd convert them to bolt in as mentioned - at least on the bottom. Grind out the left over burrs and then start drilling. I've always found the bottom buffers a pain to clip in with progressive springs and damned near impossible while the forks are in the bike.
Posted: Wed Nov 10, 2010 12:08 am
by dapper
What they said^^^^^
Posted: Wed Nov 10, 2010 8:08 am
by red ghost
MarkH wrote:I'd convert them to bolt in as mentioned - at least on the bottom. Grind out the left over burrs and then start drilling. I've always found the bottom buffers a pain to clip in with progressive springs and damned near impossible while the forks are in the bike.
Maybe you just need to man-up!
Posted: Wed Nov 10, 2010 8:15 am
by MarkH
Posted: Wed Nov 10, 2010 12:24 pm
by red ghost
