Clutch centre nut
Posted: Sun Nov 07, 2010 10:32 am
by djh66
Does anyone know of any ways of removing the nut, without the use of a clucth holding tool? Without causing damage to the casing etc.
Re: Clutch centre nut
Posted: Sun Nov 07, 2010 10:39 am
by bristolmod
you can bodge it with a screwdriver but................................
you may either break the casing, or more likely bend the "spider"
The tool is the correct way and is relatively cheap
Sorry!
Posted: Sun Nov 07, 2010 11:10 am
by red ghost
Impact gun...
Posted: Sun Nov 07, 2010 11:45 am
by djh66
red ghost wrote:Impact gun...
I've tried it with my impact gun, but....no luck!
Posted: Sun Nov 07, 2010 2:28 pm
by Mag
You can make a holder out of an old metal plate a short length of metal and a bolt. Mine has half a cable clamp from a Vespa loosly bolted to the plate. The clamp has holes at both so the other end drops over a casing stud.
Posted: Sun Nov 07, 2010 4:54 pm
by djh66
Thanks for replies, done it now...plenty of WD40 and impact gun.
