PHBH carb - out of the box
Posted: Sat Nov 06, 2010 1:17 am
by Muttley McLadd
Anyone know what jets/needle/etc is in a PHBH when it comes out of the box, unmolested?
Seems dealers are a bit cagey about telling me.. Seems they want to double the price to sell me more unsuitable bits.
I've sussed a 40 slide is standard. The best answer I've got so far is that they come jetted 'rich'. Not overly helpful..
Re: PHBH carb - out of the box
Posted: Sat Nov 06, 2010 8:23 am
by soulsurfer
Speak to Eurocarb,
www.dellorto.co.uk you can order it prejetted to what you want at no extra charge I believe.
Posted: Sat Nov 06, 2010 8:45 am
by Muttley McLadd
Still about twice the price of SIP though.
I'm just curious about which atomiser/needle they come with. I'm realistic about having to get a slack handful of main jets and pilots.
Posted: Sat Nov 06, 2010 9:27 am
by Ian Hepworth
Muttley McLadd wrote:Still about twice the price of SIP though.
There are about 20 different 28 and 30mm PHBH carbs. With adjuster screws on one side or the other, rubber mount, solid mount etc.
Then they all have different combinations of atomiser,needle,main, choke, idle.
All for different OEM applications.
Posted: Sat Nov 06, 2010 9:31 am
by Muttley McLadd
Cheers fella.. nobody else could tell me that.
I'm after a 30mil, rubber mount. I was under the impression (one dealer told me..) that the adjuster screws only come on the one side.
I'll order a handful of needles and atomisers too then
Posted: Sat Nov 06, 2010 9:57 am
by rocho68
talk to cambridge lambretta , very helpfull and will send what you reqiure !!!!
Posted: Sat Nov 06, 2010 10:05 am
by Ian Hepworth
Muttley McLadd wrote:Cheers fella.. nobody else could tell me that.
The adjusters come on both sides. If there is a D in the part number it normally means the adjusters are on the right (D=destra, Italian for right).
If there is an S it's left (S=Sinistra, Italian for left).
Posted: Sun Nov 07, 2010 10:29 pm
by corrado
Just opened up a couple of my stock, factory fitted with ...........
PHBH 26. BS
Main 110
Pilot 50
Choke 70
Slide 40
Needle X7
Atomiser AV266
PHBH 30. BS
Main 115
Pilot 55
Choke 70
Slide 40
Needle X2
Atomiser AS266
HTH.
