Clutch centre nut
djh66
Main scooter: 150 special
Does anyone know of any ways of removing the nut, without the use of a clucth holding tool? Without causing damage to the casing etc.
Bring Me Sunshine COYH
bristolmod
you can bodge it with a screwdriver but................................
you may either break the casing, or more likely bend the "spider"
The tool is the correct way and is relatively cheap
Sorry!
Scootering since 1968.
red ghost
Main scooter: lambretta gp150
Impact gun...
djh66
red ghost wrote:Impact gun...
I've tried it with my impact gun, but....no luck!
Mag
Main scooter: Carbon GP TS1
You can make a holder out of an old metal plate a short length of metal and a bolt. Mine has half a cable clamp from a Vespa loosly bolted to the plate. The clamp has holes at both so the other end drops over a casing stud.
djh66
Thanks for replies, done it now...plenty of WD40 and impact gun.
