What's the trick?
Posted: Fri Nov 05, 2010 9:28 am
by red ghost
What's the trick for keeping off-set frame cones align?
cheers
Re: What's the trick?
Posted: Fri Nov 05, 2010 9:59 am
by soulsurfer
Loctite ;-)
Posted: Fri Nov 05, 2010 10:09 am
by mark
Hold in place with small grub screw thru frame in line with gap in cone. It's best if you put a divot in cone as well
Posted: Fri Nov 05, 2010 11:04 am
by AUSSIE
do you mean allowing the grub screw to locate into the slot in the cone? wont this stop the slot closing to pinch tight on the mounting rod?
I'm interested because I am having clearence problems on my TS
Posted: Fri Nov 05, 2010 11:42 am
by red ghost
But do they close down?
Posted: Fri Nov 05, 2010 12:23 pm
by Stampede
LTH has slotted ones together with a special bolt - it´s adjustable from the outside!
Posted: Fri Nov 05, 2010 12:37 pm
by mark
Do this after you have tightened it up
Posted: Fri Nov 05, 2010 9:00 pm
by camel
silly cone!!!!!!!!!!!!
