any experts on electrics and wiring loom out there??
Posted: Sun Oct 31, 2010 9:47 pm
hi all, scoot is indian gp brought from rayspeed as one of their restored scoots 3 years ago. i havde recently purchsed a 120watt bgm stator as an upgrade from my indian one after having some problems with misfiring etc. but i now cant get a spark at all. i know nothing about electrics and am really struggling. i have checked all the usual checks that i have been advised ie plug, removed the green wire (ignition swithc) and also the green from the stor to see if i get a spark off this but still nothing. the flywheel fits on fine and no rubbing on pickup although i did notice that the inner boss did appear very close to the green wire going to the coil that meets with the white wire and am concerned it may rub!
someone has mentioned tipes and checking trigger points but i could do with this being explained a bit simpler and in more depth
the other thing is that i would like to get rid of the juction box and go from the stor straight into CDI however i already have wires connected to the CDI a green one( witch i belive is igntion swithc and i think a white one and the one on top i think is 2 wires joined together, i think one of them is purple and possibly striped and i think it is with a brown wire, in the juction box i have green, white, yellow and brown and into that i had prevsiously had the 4 wires from the stator although on my new stator i dont have a brown wire but a red one, also the brown and red are not a staright swop as the yello wire that was on the old stator was connected to the pikcup where this time it is the red one, so that has resulted in the yellow from the new stator having to go where the brown went from the olf one and the red wire going where the yellow went! confused? i have researched this on the net and cant even fined out which type of loom i have and which wires to joing together etc to get rid of the wire loom and take out the wires that i have in the cdi box so that i can put the stator wires straight into it! i may not have explained myslef very well, but if you can understand what im trying to say, any help would be greatly appreciated as i need to get this scoot back on the road as its my main mode of transport and currently having to use the mrs car, so shes walking and aint happy
