SR Kit piston replacement
Posted: Tue Oct 26, 2010 6:46 pm
by des
Is there a piston i can get to straight fit into an SR186 kit, i know i could use a suzuki piston by changing con rods, i want to use the SR barrell on an LI150 and dont want the expense of having to change the con rod and possibly the flywheel as well. Thanks in advance
Re: SR Kit piston replacement
Posted: Tue Oct 26, 2010 7:09 pm
by CPH Lambretta
Deanspeed from USA do one :)
Posted: Tue Oct 26, 2010 7:18 pm
by guygrrr
Posted: Tue Oct 26, 2010 7:25 pm
by storkfoot
MB Racetour. I did use to have a Deanspeed but found that the barrel needed a rebore after about 3000 miles. I can only presume the rings were too hard for the steel liner :? . I've run the Racetour for maybe 6000 plus and no signs of needing a rebore.
IMO, if you spend on an MB piston (they aren't cheap), make sure you get the piston/bore tolerance professionally checked and maybe get the head matched to the piston.
Posted: Tue Oct 26, 2010 8:41 pm
by ForemanBob
Have you looked on the Scooter Restorations site... a good range of pistons in oversizes to suit the kit exactly
Posted: Tue Oct 26, 2010 8:53 pm
by rocho68
BEEDSPEED 190 PISTON , JUST REBORE AND DONE £ 39.99 :D
Posted: Tue Oct 26, 2010 9:29 pm
by Bofs
Posted: Fri Oct 29, 2010 12:48 pm
by des
rocho68 wrote:BEEDSPEED 190 PISTON , JUST REBORE AND DONE £ 39.99 :D
This is the cheapest option for me at the moment, how much of a rebore would be needed the beedspeed piston i looked at was 64mm is this not the same as the cylinder dia. would i not be able to do a straight swop.
Posted: Fri Oct 29, 2010 5:08 pm
by corrado
http://beedspeed.com/product_info.php?c ... ts_id=6596 That should fit straight in, it's 64mm and your barrel should be 64mm. Check clearances and ring clearances before assembling. The ebay one mentioned above should fit straight in too.
Posted: Fri Oct 29, 2010 7:08 pm
by bristolmod
if you're not reboring/ honing, don't forget to "glazebust" the barrel so the new rings can bed in
Chris
