Exhaust end/tip missing
Posted: Mon Oct 25, 2010 8:05 am
by westburyst
Hello,
The end of my exhaust is missing, would this have a negative effect on the performance/fuel efficiency of my GP200. It was like this when I got the scoot so not sure if it is running normal or abnormal. Seems to run fine.
I am thinking of attaching something suitable, as similar as possible in length and cylinder diameter as original - is it worth doing this? Would it be good or bad for performance/fuel efficiency etc??
Attached shows the highlighted in red area is missing.
Cheers
Re: Exhaust end/tip missing
Posted: Mon Oct 25, 2010 7:50 pm
by storkfoot
The original Lynx exhaust was like that. Have you got a picture?
Posted: Mon Oct 25, 2010 10:26 pm
by westburyst
I'll take a picture and post
Thanks
Posted: Mon Oct 25, 2010 11:11 pm
by westburyst
Posted: Thu Oct 28, 2010 9:45 pm
by westburyst
No takers
Posted: Fri Oct 29, 2010 12:23 am
by storkfoot
It's not a Lynx one. I'd have to say if it was my scoot, I'd at least try a standard 200 exhaust to compare the two. I wouldn't bother trying to fix an end pipe.
Have you asked the person you bought it off about the background to this exhaust?
Posted: Fri Oct 29, 2010 11:52 am
by Doom Patrol
It's something I've seen a lot of on Maltese scooters for some reason and knowing what they are like over there I'd suspect they think it gives it a boost for no extra money. Because they won't pay money for anything if they can help it.
Whether it does or not I don't know. I'd suspect not and that it might make a standard engine feel a bit gutless.
Posted: Fri Nov 05, 2010 8:52 pm
by joey
...bin it buy a ancillotti or af clubman.....its broke off probably because its not been secured to crankcase....
Posted: Fri Nov 05, 2010 8:58 pm
by RICSPEED
westburyst wrote:
wtf is that thing ....pidgeon spike??
Posted: Sun Nov 07, 2010 1:44 am
by westburyst
:anbrgin; Lol yep pigeon spike. I live in a block of apartments and these damn things keep falling off from the window ledges/roof edge etc...
yep i will be replacing the exhaust.
Cheers
