Page 1 of 3
Lambretta inboard disc brake kit for drum links
Posted: Mon Oct 25, 2010 4:06 am
by scootRS.com
As original but updated, and the only high pressure cast one available.
The unique feature of this version is
we have cast the back plate to use common drum links! No longer do you need to find and buy expensive disc links. Everything else is as original.
$259 (or today
in pounds...)
For more info, see our
Lambretta inboard disc brake kit for drum links onsite.
We have also made the
inboard disc back plate for drum links available separately if you have a disc kit already but want to use it with drum links.
Re: Lambretta inboard disc brake kit for drum links
Posted: Tue Oct 26, 2010 9:29 pm
by bicboy
I was interested to know if anyone had fitted one of these and what are they like
Posted: Thu Oct 28, 2010 4:37 pm
by dirtyhandslopez
I would have thought the original ones were cast with the extra lug for a reason....
Posted: Thu Oct 28, 2010 5:42 pm
by Ian Hepworth
dirtyhandslopez wrote:I would have thought the original ones were cast with the extra lug for a reason....
I agree. Apart from the accessory damper brackets all innocenti scooters with dampers and all with disc brakes had the extra 12mm stud.
I think they'll have done that for a reason.
Posted: Thu Oct 28, 2010 8:00 pm
by joespeed
Ian Hepworth wrote:dirtyhandslopez wrote:I would have thought the original ones were cast with the extra lug for a reason....
but the scootrs outboard disc is far better than the innocenti disc with only li style links,the new disc is very good cant really see a problem with drum style links.
regards
joe
Posted: Thu Oct 28, 2010 9:12 pm
by soulsurfer
It's not the links but the back plate that has a 12mm stud on an Innocenti inboard disc
Posted: Thu Oct 28, 2010 9:37 pm
by joespeed
soulsurfer wrote:It's not the links but the back plate that has a 12mm stud on an Innocenti inboard disc
yes but a scootrs outboard out performs the lambretta disc and doesnt have a 12mm bolt holding it onto the links!
Posted: Thu Oct 28, 2010 9:49 pm
by soulsurfer
Yes but that locates into the 5mm(?) thick stainless steel plate NOT a cast lug. The lug on the back plate is the weak point here, whereas the Innocenti inboard disc locates with a 12mm stud into the link.
Posted: Thu Oct 28, 2010 9:51 pm
by paulmgreen
??? racing is the hardest test of all........ never heard of one braking????
no need to bash ScootRS when its not warranted?
Posted: Thu Oct 28, 2010 10:03 pm
by Ian Hepworth
paulmgreen wrote:??? racing is the hardest test of all........ never heard of one braking????
race scooters don't use drum links and drum type hubs do they?
My observation was from an engineering point of view.
I wouldn't personally use a drum type disc hub of any kind, inboard or outboard.
