Taffspeed exhaust fitting problem.
Posted: Sat Oct 23, 2010 1:53 pm
by Ihateyoubutler
Re: Taffspeed exhaust fitting problem.
Posted: Sat Oct 23, 2010 2:53 pm
by col@garageartwerks
try loosening all the fittings and put the end can on the outside of that bracket it the back it should twist the can round and angle the expansion pipe down a bit.... you will have to trim a bit out of the back of the running boards to clear the pipe.... i've had 2 taffys on my bike now with no fitting problems i'm running a shortened rear shock as well as concentric cones...
Posted: Sat Oct 23, 2010 8:05 pm
by camel
col@garageartwerks wrote:try loosening all the fittings and put the end can on the outside of that bracket it the back it should twist the can round and angle the expansion pipe down a bit.... you will have to trim a bit out of the back of the running boards to clear the pipe.... i've had 2 taffys on my bike now with no fitting problems i'm running a shortened rear shock as well as concentric cones...
eccentric!
Posted: Sat Oct 23, 2010 8:06 pm
by Ihateyoubutler
Thanks for your help, much appreciated.
