Page 1 of 2
Torquing up Franspeed stubs
Posted: Thu Oct 21, 2010 7:47 pm
by sydduckett
Have just got a Franspeed rb stub and there is a tiny gap between the thread and the stub, cant get even the slimmest socket over the nut so how do i torque it up to the right tightness when i can only get a tiny piece of spanner on them?
Anyone else had this problem with sleeved stubs....any advice welcome... :?
Ta
sef
Re: Torquing up Franspeed stubs
Posted: Thu Oct 21, 2010 8:30 pm
by WINTERMODEL150
Hi sef
I had the same problem with my franspeed studs,i used longer studs and used 2 m7 nuts locking them both together with thread lock,also you can use an old chaincase guide locktab washer ,drill it out to m7 and use this as a locking plate under the first nut.
Not heard off an torque settings for these studs as far as i know.
Dean.
Posted: Thu Oct 21, 2010 8:32 pm
by Knowledge
I don't own a torque wrench Sef. Things don't seem to fall off my scooter, so perhaps you don't need one either.
Posted: Thu Oct 21, 2010 9:29 pm
by Diablo
PX125 long cylinder nuts are quite useful and can be used with the lockwasher. I torque these to 12lb/ft
Posted: Thu Oct 21, 2010 10:41 pm
by soulsurfer
Use M7 K-nuts with and 8mm socket IIRC
Posted: Fri Oct 22, 2010 8:41 am
by eibargum
If your problem as i read it is theres not enough room for a socket because of the closeness of the stub then while holding it in your hand or a vice flat off the side of the stub next to the hole with a powerfile or just a file untill you can get a socket on, had to do this on mine, the exhaust nuts off a Vespa GTS are also a good way to go.
Posted: Fri Oct 22, 2010 12:01 pm
by sydduckett
eibargum wrote:If your problem as i read it is theres not enough room for a socket because of the closeness of the stub then while holding it in your hand or a vice flat off the side of the stub next to the hole with a powerfile or just a file untill you can get a socket on, had to do this on mine, the exhaust nuts off a Vespa GTS are also a good way to go.
Are these nuts slimmer in profile allowing me to get the socket over the nut and inside the side of the stub?
Ta
Posted: Fri Oct 22, 2010 1:07 pm
by storkfoot
Have you tried one of these:
Posted: Fri Oct 22, 2010 10:56 pm
by eibargum
Ta
Yes they are, you can get a socket on but they do have a flange on the bottom, which is not a bad thing, cant take the credit though as Martin at Chiselspeed put me onto them ;) .
Posted: Sat Oct 23, 2010 6:48 am
by soulsurfer
K-nuts have a flange too, they're used in motorsport, the M7 takes an 8mm socket, they also have the benefit of self locking. Available from here ;-)
