Franspeed stub question..
Posted: Sun Oct 17, 2010 6:42 pm
by sydduckett
Got this stub for a Franspeed for my rb, its not a good fit and theres quite a bit of play. question i have is, are the 2 grooves in the stub for o-rings and if so where can you get them from? Also if i dont use them will silicone or similar do the job as theres quite a gap?
Ta
sef
Re: Franspeed stub question..
Posted: Sun Oct 17, 2010 6:58 pm
by ArKaTxU
Andy Francis have:
http://www.ekmpowershop12.com/ekmps/sho ... -336-p.asp
I want to know too if silicon or similar can do the job, because i have the same stub.
Now he have another stub:
http://www.ekmpowershop12.com/ekmps/sho ... 1610-p.asp
Posted: Sun Oct 17, 2010 7:26 pm
by bazman
Think they done away with the stub that had the o rings as you had to replace them every time you took exhaust off.
Posted: Sun Oct 17, 2010 8:50 pm
by sydduckett
What to do, what to do? Should really go for the stub but could just buy 4 rings as how often do i take the pipe off? Do you need 2 though, as there are 2 grooves? Also the one item on his site that doesnt have a buy button is yes you guessed it the stub... :x
Typical, will buzz him tomorrow.
Posted: Wed Oct 20, 2010 2:19 pm
by Bilko
What size are these o-rings?
Posted: Wed Oct 20, 2010 3:01 pm
by sydduckett
ended up buying the updated rb stub with a sleeve from Andy Francis.
Thanks for point me in the right directiom.... :D
Posted: Wed Oct 20, 2010 3:45 pm
by Bilko
I was going to buy a batch from ebay. Just need the size
Posted: Thu Oct 21, 2010 11:26 am
by sydduckett
Bilko wrote:I was going to buy a batch from ebay. Just need the size
Not sure best to call Andy Francis as he makes the franspeed and sells them. I think they need to be heat proof though?
Posted: Thu Oct 21, 2010 2:21 pm
by Bilko
Ah ok. Thanks
Posted: Fri Oct 22, 2010 9:23 pm
by Bufficus
These O rings were rubbish from the start and have not improved. I use acetoxy clear silicon sealant every time I remove my exhausts even on proper slip joints. Never had a problem.
You shouldn't have to pay £20 for a new stub due to a design fault.
