Mugello 186 v.4... pipe options?
Posted: Sun Oct 10, 2010 9:43 pm
Hi all.
I will spare you the complete background, beyond to say that I'm a long-time motorbike dork who's just dipped his feet into the world of Lambrettas. Just got a derelict LI 150 back on the road after a near-complete (and entirely not-intentional or desired) rebuild, thanks to a lot of help from Sticky's book and a lot of lurking on here. The plan was to turn it into something, I dunno... more-casual than my motorbikes that could get me and a girl and a case of beer to wherever I decide to park it with a minimum of fuss and drama, and I almost got that. The only problem now is that the LI is loud. Really, really loud. Louder at idle than my Triumph with straight, unbaffled TT pipes. And that really cuts into the "minimum of... drama" bit when I ride it.
So here's what I've got: Muggy 186 v.4 kit with matched block and manifolds. PHBH 26. Ancillotti clubman. (All of the prior sourced from Cam Lam.) Standard gear and drive ratios (willing to change if necessary). Standard wheel and tire size.
Here's what I plan to do with it: Low-key blasting around town with occasional longer-distance runs at a comfortable 55, and nothing more than a couple or three hundred miles in a day. Riding two-up with said girl (I'm 190 lbs, she's much, much less) and case of beer, and I'd like to be able to go up hills at a not-pitiful speed. Winding it out on occasion is fun, but I don't want to have to rev the nuts off of it in daily riding. I have motorbikes to go far and fast, but I would like to keep up with traffic in town.
And really, as it sits right now, it's pretty much good as-is. Still has drums both ends, and still no dampers up front, so top speed is (definitely) not a goal, but it has enough go to tear away from a stop light and seems like it'll haul enough weight (haven't tried, since it went back on the road three days ago). It's just too damn loud.
So now to my questions: Is there another pipe (clubman or expansion) that will give me similar performance with less noise? Alternatively, is there another pipe that will give me a little more performance down low (keeping in mind my intended use for the bike) with similar noise. My understanding is that the JL3 road is still going to be more peaky, the JL3 snail just sucks, and most other expansion chambers are going to be even more top-end oriented. Then there are the other clubmans, all of which will cut into performance, save maybe the Gori, which looks great, but is probably even louder and too big anyway.
... or at least that's what all I've taken away from the research I've done on this forum. Most of what I see is (understandably) more biased toward higher-revving engines or old-school tuning on iron barrels, and is thus maybe not applicable here. It wouldn't surprise me if there's a niche-market pipe that's exactly what I'm looking for, but I just don't know about it and haven't found it in my search, which is why I'm asking.
The obvious option is probably to fit the Ancillotti "retrobooster", which I assume muffles the sound of the Ancillotti somewhat, but there's one final complicating factor: I'm in the U.S., and ordering from the U.K. (or anywhere in the E.U. for that matter) costs a lot. That also means it's extremely unlikely I can find someone even relatively local who has a given pipe to listen to it. I'd really like to not order something, fit it, and then find out it's still far louder than what I'm looking for. I don't mind spending the money to get what I want out of this thing, but I'd rather not sink huge piles of dollars into shipping hollow metal across the ocean more than once.
Thanks for any advice you can give, and apologies for the length of this, but I wanted to hit all of the pertinent details in a single go.
