Page 1 of 2
Hidden front brake hydraulic hose.
Posted: Sun Oct 03, 2010 8:05 pm
by Ihateyoubutler
Anyone have any info on hiding the front brake hydraulic hose via the normal drum brake cable route? I know you have to turn down the throttle rod in a lathe.Am I right in thinking the hose has to be slimmer than normal? If so, will this still be suitable for a double disc set up?
Thanks.
Re: Hidden front brake hydraulic hose.
Posted: Sun Oct 03, 2010 8:38 pm
by DJB
I used stainlees pipe as far as the throttle wheel.I will take some more photo's for you this week as you cant see anything "That was the idea"
Posted: Sun Oct 03, 2010 9:10 pm
by carlos fandango
Ihateyoubutler wrote: I know you have to turn down the throttle rod in a lathe.
I didnt have to on mine, as the Jason frost method. but i didnt need to turn the rod down. I used the plain s/steel braided hose 6mm OD.
Posted: Sun Oct 03, 2010 10:11 pm
by jason frost
carlos fandango wrote:the Jason frost method
:D
Posted: Mon Oct 04, 2010 1:11 am
by mark
The Jason frost method worked for me as well
Posted: Mon Oct 04, 2010 4:57 pm
by Angry Bloke
:D
Please enlighten us
Unless its similar to the rhythm method. :)
Posted: Mon Oct 04, 2010 6:25 pm
by byron
Angry Bloke wrote:
:D
Please enlighten us
dash it, I saved this link to the old LCGB forum, but the photos have gone... should've saved the pics too...
It was very tidy
Posted: Mon Oct 04, 2010 6:52 pm
by jason frost
Angry Bloke wrote: rhythm method. :)
:D here you go http://www.absolutelyscooters.com/photg ... p?album=77
Posted: Mon Oct 04, 2010 8:46 pm
by Ihateyoubutler
Thanks for the help. Just a couple more questions, what diameter does the rod need to be turned down to and do I need a particular master cylinder? ( Haven't bought one yet).
Thanks again.
Posted: Mon Oct 04, 2010 8:49 pm
by mark
Didn't turn the rod down just drilled cable inner hole out to 6.5mm and use a STD scootrs master
