Clutch movement
Posted: Mon Feb 23, 2009 10:20 pm
by leehuggy72
hi guys,
i've more or less finished building my engine and like any other person was checking what i've done chain set right, gearbox shimmed correctly etc etc
What has alarmed me was the play in the clutch unit itself.. theres quite a bit of play enough for me to worry anyway. is this normal?
Re: Clutch movement
Posted: Mon Feb 23, 2009 11:42 pm
by drunkmunkey6969
leehuggy72 wrote:What has alarmed me was the play in the clutch unit itself.. theres quite a bit of play enough for me to worry anyway. is this normal?
what sort of play do you mean?
Re: Clutch movement
Posted: Tue Feb 24, 2009 12:33 am
by byron
do you mean the crownwheel rocks on the gear cluster ?
Re: Clutch movement
Posted: Tue Feb 24, 2009 1:23 am
by shocky
leehuggy72 wrote:hi guys,
from the engines ive worked on in the last 2-3 yrs id say yes its normal BUT not right, i suspect as has just been said its rocking which means the clutch spider is to long or the crown wheel is to short ,on a higher powered motor id say its critical to get it right a standard motor would be ok ish , but will wear the chain and sprockets leading to swarf in the oil which will lead to the drive side seal to leak a s**t job to fix
Re: Clutch movement
Posted: Tue Feb 24, 2009 6:42 pm
by leehuggy72
byron wrote:do you mean the crownwheel rocks on the gear cluster ?
Yes mate there's side to side play not a massive amount tho..
Re: Clutch movement
Posted: Tue Feb 24, 2009 6:51 pm
by drunkmunkey6969
did you check the crown/spider clearance and also measure shim etc?
Re: Clutch movement
Posted: Tue Feb 24, 2009 8:41 pm
by leehuggy72
i've followed sticky's book to the letter, the clutch spider is solid with no side movement, its the crown wheel which has the sloppy play..
i'm seriously thinking of going back to after the gearbox as that is fine and redoing what i've done just to see if i've dropped a
