Disc pads
Posted: Sat Oct 02, 2010 11:47 am
by bristolmod
standard front disc on a TV175 S3.
Just had its MOT, and the tester told me the front brake was "just within spec"
Recommended that I look for some "abrasive EBC" pads if possible. Anyone know if there is such a thing, or any ideas as to how to improve a standard set up- don't want to go hydraulic.
Any suggestions Gents?
Chris
Re: Disc pads
Posted: Sat Oct 02, 2010 12:43 pm
by ArKaTxU
Sintered pads + reverse pull?
Re: Disc pads
Posted: Sat Oct 02, 2010 6:27 pm
by wack 63
Try EBC FA 100 pads http://www.ebcbrakesdirect.com/bike/par ... 9&sec=Euro Seem to work fine although won't pull a stoppie with a cable set up :) Don't worry about the wrong pic on the site
Re: Disc pads
Posted: Sat Oct 02, 2010 10:14 pm
by rog60
Just fitted Newfren sintered pads(bought from Glasgow Lambretta) to my remade inboard disc brake.Much,much better than the un-named brand previously fitted :)
Re: Disc pads
Posted: Sat Oct 02, 2010 10:21 pm
by J1MS
I fitted the same to my TV before the euro, there pretty good.
Re: Disc pads
Posted: Sat Oct 02, 2010 10:34 pm
by J1MS
Need better brakes on mine thinking of losing the standard look disc and fitting an outboard instead, nearly hit a car in the outside lane on the M62 going to the euro hadto cut back into the inside lane to avoid a crash brakes not good enough at speed, still on a standard cable not even reverse pulled.
Never seem to get time to do my own scooters.
Re: Disc pads
Posted: Sat Oct 02, 2010 10:37 pm
by joee
rog60 wrote:Just fitted Newfren sintered pads(bought from Glasgow Lambretta) to my remade inboard disc brake.Much,much better than the un-named brand previously fitted :)
is that the copper coloured ones? squeal like buggery..
Going to order a better disc and pads from al diablo...should have done it earlier
Re: Disc pads
Posted: Sun Oct 03, 2010 9:50 am
by Arch_Stanton
Fitted a set of these a couple of years ago, very effective but only had to touch the lever and as mentioned they squealed, is there a cure for this?
Re: Disc pads
Posted: Sun Oct 03, 2010 9:04 pm
by rog60
No grey with metal dust impregnated, black lacquered. had to grind them down a few thou on outside edge to fit properly....don't squeal.. put copper slip on backs to prevent that :shock: :shock:
Re: Disc pads
Posted: Mon Oct 04, 2010 11:15 am
by bristolmod
Thanks Gents- some good ideas here.
Going to try the sintered route first
Chris
