Oil leak – opinions if you please
Posted: Mon Sep 27, 2010 8:19 pm
by lockman69
I have a TS1 engine, that’s been sitting on the floor of my workshop, at some point the engine has been rolled over on its side....I’ve just got around to picking it up and noticed that oil has been leaking from the gear arm....is this normal to lose oil from here if the engine is upside down or on its side, or does it indicate that there is a seal that needs replacing?
Cheers
Re: Oil leak – opinions if you please
Posted: Mon Sep 27, 2010 8:31 pm
by lockman69
I know it’s not normal, bloody O ring needs replacing ......ARSE!
What would happen if somebody was to leave it and not bother ripping out the gear box just to replace a silly little O ring?....only leaks when its upside down lol.
Posted: Mon Sep 27, 2010 8:33 pm
by Daggs
There is an o-ring seal under the gear arm and the gear shaft passes through a bush that could be worn.
However the seal is there to stop oil that is splashing around in the gearbox from escaping. It's not normally subjected to being 'submerged' in oil.
Posted: Mon Sep 27, 2010 9:15 pm
by 10 inch Terror
Daggs wrote:There is an o-ring seal under the gear arm and the gear shaft passes through a bush that could be worn.
I agree, no need to change anything.
Posted: Tue Sep 28, 2010 12:54 am
by corrado
I replaced the bush on one as it leaked in use and the oil found it's way into the brake drum. Oil n brakes don't mix well, good job I had a front outboard disc.
