30mm Dellorto Vs 30mm Dellorto
Posted: Fri Sep 17, 2010 11:44 pm
I run a PHBH 30mm on solid mount CDC manifold. I have a plan to get the solid mount machined down and fit a new rubber mounted carb.
The solid mount carb works quite well (it has never had occasion to fall off!). The solid PHBH 30 is now old , well worn and has problems getting a tickover, slide is loose and worn threads on throttle cable cap. The manifold is also long and would benefit induction if shortened (it has already been flowed to the barrel so want to re-use).
When I come to putting on a new carb would there be a noticeable difference between a new PHBH 30 roundslide (possibly the powerjet) and a 30VHSH flatslide?
I have a VHSH already, it's jetted for an Imola I believe, although, never fitted it. The new rubber PHBH could be set up same as existing carb and run well if not a little better with shortened manifold. Current set up has been dyno'd so I know it's ok. To use the VHSH would result in another series of dyno sessions...for what extra gains?
Would I see major benefits using the flatslide(once set up/dyno'd) over a PHBH?
Currently:
RS Tuning Suzuki 190 (TV Barrel and rodded crank)
30 PHBH solid mount
44mm RS Clubman
AF-Ducati with static timing set at 19
want to try:
Chiselspeed M-tech advance/retard
Mickek MK ?? (Looks like a DJ)
and a new 30mm Dellorto
Thanks
Currently:
30 PHBH solid mount
44mm RS Clubman
want to try:
Thanks
