slotted/grooved brake shoes
Posted: Fri Sep 17, 2010 10:33 am
by lambrettasam
Hi all,
I saw some on an ebay advert. What are the benefits of fitting them? and where to find them?
thanks for your help,
S
a
m
Re: slotted/grooved brake shoes
Posted: Fri Sep 17, 2010 10:52 am
by bristolmod
I would say that on a standard scooter with cable operated brakes, they would make no difference whatsoever, and may in fact worsen the situation (less contact area due to the grooving)
However, on a well set up hydraulic system they should help reduce fade due to better pad/ shoe/ disc/ drum cooling.
BUT.....it all depends on the friction material used, and what temperature it was designed (if indeed it was designed and not simply "altered" with a junior hacksaw in some far off back street sweatshop....) for.
Personally, replacement brake shoes and pads vary tremendously in their ability to work, so I always try to use some original "Innocenti" ones from the spares box (suitably cleaned up of course!) on a standard scooter.
Posted: Fri Sep 17, 2010 12:53 pm
by corrado
Heat build up between pads and disc creates gases that try to push the pads away on a disc brake setup which reduces the braking effect, the grooves create an escape path for those gases. Not sure if the same effect occurs in a drum system. I've seen the Newfren shoes described as "Aqua", possible reference to grooves in tyres being effective in removing water to stop the tyre aqua-planing in rain but I'd imagine that doesn't apply within a drum brake. Very nice quality shoes though.
Posted: Sat Sep 18, 2010 6:59 pm
by wack 63
All the ones I have tried have been crap, the linings are too hard.Best stick to Innocenti originals or Indian " Mikano" ones work well.The idea with the grooves is to disperse the dust etc and keep the linings cleaner.
Posted: Sat Sep 18, 2010 7:39 pm
by RICSPEED
every thing ive ever had with drums (two wheels at least) have had grooves put in them seems to work for me
Posted: Sat Sep 18, 2010 7:47 pm
by lambrettasam
nice to get different opinions on this. I'll try them out and give my opinion to this threat.
Thanks for the replies.
s
a
m
