mugello 225 port timing help????
paulski
i have latest version muggy 225, 60mm mec crank and port timings are ex:182 transfers :127 and inlet:164 and squish 1.2mm. left packer plate out to get squish right. sterling pipe and sx200 box with 15/47 and oko30mm carb.timing set at 19 degrees... had it dyno'd yesterday and showed 15.9 bhp @ 7000rpm.and 16 torque at same time.... which is not too bad but power curve dips a bit just before midrange so makes it a bit peaky, and that shows on the road cos it feels like a headwind would be a struggle.ie not very torque until topend..... wot would be the best approach, to beef up the midrange punch of the motor,should i widen the exhaust port? or pack barrel up and lower head into barrel??? i noted that at b.d.c the piston crown is 1,5mm lower than the exhaust port floor,so if i pack the barrel this will obviously make this worse which i am sure is not good, do i go for a longer conrod than the standard 107 thats in now??? any ideas or expertise please anyone. also carb needle is a jjh on 3rd clip/122 main. is there a better needle that would cure this?? tried a few but this was best i had.
jonny snatchsniffer
sx200/tv175 is probably not the best box to use tbh, gears too far apart, tho with yr port timings ive never had a problem with simmiler cast iron tuned barrels but with 15/46, i found it much better with a pacemaker box with 17/46
paulski
jonny snatchsniffer wrote:sx200/tv175 is probably not the best box to use tbh, gears too far apart, tho with yr port timings ive never had a problem with simmiler cast iron tuned barrels but with 15/46, i found it much better with a pacemaker box with 17/46
cheers ive got a pacemaker box,may give it a go but while engine on bench i want to do whatever i can to get it spot on if poss. to measure exhaust port width should i hold a piece of paper down the barrel against the port and take a rubbing and then place paper flattened out on table and use a vernier,is this an accurate way of measuring width???. i think mine is aprox 68% of bore size, how far can it be widened safely??is it a specialist job cos of nicasil or can it be done with a dye grinder.
Depends how far you want to go mate...how long is a piwce of string etc etc? 16ft-lbs is respectable, but 16bhp is a bit low for a 230cc.
Personally, if it were my scoot, i'd run a different pipe, a close ratio gearbox and have the cylinder ported (the 70% will help, but you have more issues than that).
However...if on a budget, get the cylinder done first....and see how you get on, then try a different pipe...and lasty...if still not happy, split the engine and add the close ratio box that you have.
paulski
drunkmunkey6969 wrote:Depends how far you want to go mate...how long is a piwce of string etc etc? 16ft-lbs is respectable, but 16bhp is a bit low for a 230cc.
when you say ported are we just talking exh port width??? who can you recommend to do any port work on the barrel??? any suggestions for better pipe???. just a thought but if its more rideability im looking for should i just flog the kit and get a rapido225 or is the muggy gonna do the bis???? is the inlet timing too tall on the muggy with 60mm crank???should i change for longer rod????
joey
...i'm well pleased with my ancillotti exhaust on my 200 mugello....mate runs 225 19/47 gp ancillotti.....very good mid range and revs on till it sounds like its goin to blow!
    Users browsing this forum: Semrush [Bot] and 8 guests
