Flow rate
Posted: Sun Sep 05, 2010 2:17 pm
by des
Is the flow rate to my fast road tune TS1 fast enough it take`s 55 seconds to fill a pint glass, it has an inline mesh filter and its a fast flow tap. I had piston rings melt into a wisco piston before and it was suggested to me my fuel flow rate was not enough to keep up, i was running at the time a narrower fuel line and a smaller filter but have changed to larger line and filter and now have the flow rate mentioned above.
Re: Flow rate
Posted: Sun Sep 05, 2010 8:06 pm
by byron
I'd be happy with that.
you're unlikely to ever use a pint of fuel in a minute
Re: Flow rate
Posted: Sun Sep 05, 2010 9:19 pm
by jason frost
Take the float bowl off the carb and see what its like.
Re: Flow rate
Posted: Tue Sep 07, 2010 2:10 pm
by des
jason frost wrote:Take the float bowl off the carb and see what its like.
I had the float bowl off and all is fine some fine dirt not alot i blew out the jets with compressed air, or do you mean something else.
Re: Flow rate
Posted: Tue Sep 07, 2010 2:20 pm
by RICSPEED
des wrote:jason frost wrote:Take the float bowl off the carb and see what its like.
i think he maybe suggesting the flow rate through the float bowl while off the carb if you follow me
Re: Flow rate
Posted: Tue Sep 07, 2010 8:49 pm
by bristolLambretta
I found i had to ditch the inline filter on my mugello with 28mm as it wasnt up to the job. As said above, a pint in under a min seems fine. Does it still flow at that rate when the tank is say a third full? I had issues when running low with flow rate, it was fine when full. With inline filter removed no issues. Maybe my cheap filter!!
P
