Kawasaki damper fitting problem
Posted: Wed Sep 01, 2010 3:14 pm
by Bilko
Finally getting round to fitting the Kawasaki dampers, but the gaps to big for the stud mount. :(
Does someone make a sleeve for them?
Re: Kawasaki damper fitting problem
Posted: Wed Sep 01, 2010 4:24 pm
by J1MS
SLJ made over sized studs for them.
Some supplied new bushes others beat a bit of tin into shape to make a bush.
Posted: Wed Sep 01, 2010 4:56 pm
by hungdog
J1MS wrote:SLJ made over sized studs for them.
Mine got a pvc type sleeve, but don't know where it's from.
Posted: Wed Sep 01, 2010 8:59 pm
by Bilko
Balls! I was hoping for a quick sollution. :(
Posted: Tue Sep 14, 2010 8:58 pm
by Bilko
If anyone is interested, I was pointed to this fella.
Posted: Tue Sep 14, 2010 10:00 pm
by paulski
Bilko wrote:Finally getting round to fitting the Kawasaki dampers, but the gaps to big for the stud mount. :(
i fitted some to my series 3 last year, if you just press the bushes and sleeves out of them and fit some from standard lammy dampers if you have any old ones knockin around, dead easy to do in a small vice. worked perfectly on mine although i removed them a while back cos they just dont really work on lammys you will find, once you have ridden it for a while.. unfortunately they are the same rate compression and rebound where as you really want them to compress easier and stiffen on rebound,just found them to be too soft or too hard when adjusted, i have fitted some cheap escort fat type and the ride is much better.
Posted: Tue Sep 14, 2010 10:20 pm
by minotaur
this is what i bought, http://www.ekmpowershop2.com/ekmps/shop ... 1651-p.asp, but you could find some brass or steel tube of the correct diameter to fit
Posted: Tue Sep 14, 2010 11:50 pm
by red
My concern is why are you fitting dampers to a wall :D :D
Posted: Wed Sep 15, 2010 1:21 pm
by Bilko
Thanks for the info lads. (except Red) HAHA! :lol: :frog:
